Joined: 10/29/2020(UTC) Posts: 1  Location: Atlanta, GA
I am trying to set up audio busses in my project. I don't see them anywhere. I am attaching a screenshot because I think they should be labeled A and B somewhere, but they are no where on this page. ScreenshotWhat am I missing?
The helpfiles maybe? ;-) (Audio Outputs)
Settings -> Audio outputs
Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
Same output device and channels for both audio buses? Try changing the channels (BUS A: 1+2 / BUS B:3+4)
Joined: 10/30/2020(UTC) Posts: 4  Location: Sao Paulo
Try to re set-up audio output, and mark just "enable" on A B C etc...
Because it's disappears when it is set up for an audio output from an external card, but it is not connected to the computer, or there is an error installing this card
