twokingsfilms
#1 Posted : Tuesday, October 27, 2020 7:53:45 AM(UTC)
twokingsfilms
Hey everyone,
First time poster, long time reader...big fan...
Anyways, I've been using vMix for about 7 months now, and I definitely don't know much about it, so I'm sure my issue is probably something simple. Previously I was bringing in my Behringer X32 COMPACT mixer as an Audio Input using X-LIVE ASIO. This morning, after updating to the latest version of vMix (I was previously on an earlier version of 23, so not a HUGE gap in updates) this option is longer available to me. In each of my vMix Preset Projects the audio input is listed as Offline and any attempt I make to reconnect is met with the following error:
vMix_ASIO Error.jpg (82kb) downloaded 3 time(s).
If the above image doesn't attach then the text for it is below:
Unable to initialize ASIO device: X-LIVE ASIO Driver, BASS_ERROR_DRIVER
#2 Posted : Tuesday, October 27, 2020 12:40:46 PM(UTC)
@ twokingsfilms
Have a look at this knowledge base article:
https://www.vmix.com/kno...ubleshooting-asio-errors
twokingsfilms
#3 Posted : Wednesday, October 28, 2020 5:20:47 AM(UTC)
twokingsfilms
Thank you very much @IceStream
Turns out it was just a matter of restarting the mixer (massive facepalm). Weird that it occurred right when I did a vMix update -- which led me towards the wrong conclusion, not the obvious one.
But all is well again now, thanks so much!
Paul Fuhrmann
#4 Posted : Wednesday, October 28, 2020 6:36:11 AM(UTC)
Paul Fuhrmann
Germany
Was thanked: 9 time(s) in 8 post(s)
The X-32 and the Midas Brothers have one Issue with thier Cards.
There are Two Card Versions out.
One with USB&Firewire and one with USB only.
Unfortunately they require different drivers to work. Even if you just use USB. Both of the cards named similar to make it hard to find out.
This is hard if you get a rental one.
db@davebelis.com
#5 Posted : Thursday, November 5, 2020 11:07:56 AM(UTC)
db@davebelis.com
I cannot get any ASIO driver to work in vMix. ASIO4ALL instantly crashes vMix. Behringer x32 will not work. Zoom F6 will not work.
All are disable so the OS isn't grabbing them. Additionally, ASIO4ALL prevent NDI Studio Monitor from working properly.
This link solved that:
https://forums.newtek.co...-without-error?p=1559398
But I am stumped on ASIO Inputs. Any ideas?
Update: 8th Time is the charm. Uninstalled all ASIO drivers. New installation works. Haven't bothered with ASIO4ALL again due to NDI issue.
Guest (4)
