GraceMaryville
#1 Posted : Tuesday, October 27, 2020 4:33:36 AM(UTC)
GraceMaryville
We are currently using vmix as our broadcast software on One desktop computer, and EasyWorship 7 on a separate computer for our words. We are capturing the output as an NDI output from EW7 to have our words on the livestream in vMix.
What we would really like is for the congregation to see only the words on the projectors, and the livestream audience to see the words overlaid on a camera input. Is this possible with EasyWorship 7 in vmix? We have the standard version of vMix.
Thanks!
SportsNetUSA.net
#2 Posted : Thursday, October 29, 2020 4:13:41 AM(UTC)
SportsNetUSA.net
Here's one way to do it.
Try setting up your words in EasyWorship with the Text on a mono color background. Capture the output as you do as an NDI output from EW to vMix.
On the NDI Input channel in vMix go to the Gear Icon, then Colour Key and you should be able to key out the background color turning into a transparency.
https://www.vmix.com/help23/inde...utSettingsColourKey.html
#3 Posted : Thursday, October 29, 2020 4:34:36 AM(UTC)
Does EW not export NDI with transparency like vMix can ?
SportsNetUSA.net
#4 Posted : Thursday, October 29, 2020 6:57:36 AM(UTC)
SportsNetUSA.net
I don't use EasyWorship, but from looking at the knowledge base on their website, it would appear that a transparency can be set up, so can chroma keys.
