Joined: 5/3/2020(UTC) Posts: 35  Was thanked: 1 time(s) in 1 post(s)
What is the best way to optimize audio in Vmix when using vmix call? Right now I see that it puts vmix caller audio on one track and me (lone host) on another. Curious how others post process their audio to make it shine.
Thx
Start off with having your callers a proper mic and set up properly (close, proper room/surrounding etc) Garbage in Garbage out
Joined: 12/16/2019(UTC) Posts: 87  Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I always put limiter plugin (FabFilter L2) on every channel and also on master. It is best way to maximize level and prevent crossing 0db (clipping). Sometimes I use EQ to get rid of annoying frequencies , most of the time it is around 1Khz and also Deesser and compressor. I came from audio production and this is must for me.
Thanks all. I need to spend some time isolating and processing guest channels
