[SOLVED] Alpha Key not working anymore
Joined: 1/22/2020(UTC) Posts: 47  Location: Montpellier Thanks: 14 times Was thanked: 2 time(s) in 2 post(s)
Hi everyone ! I have been using Vmix's key/fill feature with a decklink Quad 2 card, signal going into an ATEM studio. It used to work fine, but doesn't work anymore for no reason at first sight. I've followed the same guide as I did last year : https://www.vmix.com/help23/index.htm?KeyFill.html and with the same configuration it does not work. Does anyone has some idea ? Thanks a lot, David
I have found my problem : when creating a new VMIX session I might not have selected the same framerate as my Decklink card. Now it all works perfectly
