I am currently on a 60 day trial of Vmix in the hope that it will allow me to incorporate local High Resolution RTMP streams into Vmix and then output as an external device to OBS.
Everything works fine and Vmix picks up my stream fine, however there is a slight stutter to the playback. this can be seen every 2-3 seconds and is visible on both the preview and external output.
The stream plays back fine when accessed through a web based flash player (http://www.wowza.com/resources/3.5.0/examples/LiveVideoStreaming/FlashRTMPPlayer/player.html) and also when using RTMPDump piped to VLC.
Are there any known issues with RTMP playback, and is there anything I can check to try and resolve this?
Many thanks in advance
Thanks: 2 times Was thanked: 3 time(s) in 3 post(s)
I just did a test with RTMP and RTSP video stream, and it works perfectly under last version of vmix 11
Olivier
