Joined: 4/22/2020(UTC) Posts: 1  Was thanked: 1 time(s) in 1 post(s)
I'd love the ability to group shortcuts, so I can change the key or button for all the shortcuts in the group at once.
For my standard vMix Call builds, I make a "green room" and a "live room" for each caller. I have several shortcuts that all correspond to a Stream Deck button for changing the caller from green room to live (it changes audio busses and return sources.) But since each Stream Deck gives out unique button IDs, I have to change a few dozen shortcuts if I move computers or use a different Stream Deck. It will also make it easier to recognize what each shortcut does since the character count is limited for the shortcut name.
 1 user thanked 4kmedialive for this useful post.
I too would like to see this as a feature request. I have a pretty large production and use the StreamDeck XL. It is difficult to search through the shortcuts when i need to make changes.
