fekir08
#1 Posted : Saturday, October 17, 2020 6:59:58 PM(UTC)
fekir08
Spain
My idea is that when you select the value from a drop-down list in the other field, the corresponding value is automatically loaded.
For Example:
I have two list:
List1: BENZEMA, SERGIO RAMOS, HAZARD
List2: 09, 04, 23
So if I select the BENZEMA value in the first list, the value of 09 is loaded automatically in the other field.
What I want to achieve is that selecting the name of the player in my template will load the photo of that player.
[img]https://ibb.co/QfRWSc5[/img]
#2 Posted : Saturday, October 17, 2020 7:35:54 PM(UTC)
Why do they have to be separate lists as the image is directly related to you name list ?
Assume by template you mean a title and the list is a datasource linked to it ?
I so name all the photos the same to the persons name and have your title field format set to something like d:/{0}.jpg where {0} would become the persons name
fekir08
#3 Posted : Saturday, October 17, 2020 8:18:09 PM(UTC)
fekir08
Spain
The reason for adding two lists is because in my template I get the data:
txtLISPLAYER: BENZEMA
imgPLAYER: benzema.png
I had not thought of doing it as you say.
As I understand it would be like this:
For example if I have only a list of players in UTC: Benzema, Hazard, Sergio Ramos.
How can I make it in the template to take the value of the player's name so that it loads the photo automatically?.
Thank You,
#4 Posted : Saturday, October 17, 2020 8:40:51 PM(UTC)
Sorry not in dept familiar with the excellent UTC as i make custom controllers for my needs and use datasources directly
