Feature Requests
Ability to SOLO more than 1 audio channel
Rank:: Member
Joined: 9/7/2020(UTC) Posts: 13  Location: Louisville Thanks: 5 times
This is regarding remote video callers.. I have my Talent on Bus A&B (they listen to BUS B), a producer and me on Bus B. I SOLO BUS A so I can hear the Talent without me(good) but I also now cannot hear the producer mic(bad)... If I could also SOLO the producers' audio channel, I'd have Talent + producer - me (good)...
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
If you have a spare bus you could assign the inputs you want to that and then solo that bus. (enable the buses in settings then right click the A/B bus toggles on an input to get to the other busses) So talent on A,B&C, producer on B&C, you on B then you can solo C.
Rank:: Member
Thanks but I need to listen to the program feed (Bus A will be routed to program when the show starts) without my headset mic but with the the producer mic (off program). Every audio mixer I've ever used has the ability to have multiple channels/busses SOLO and that seems to me to be the easiest way to do this.
Joined: 7/17/2020(UTC) Posts: 59  Location: Makati City Thanks: 11 times Was thanked: 5 time(s) in 5 post(s)
When you click on the Solo button with your mouse, you can only select one at a time. However, when you assign shortcuts/triggers you will be able to Solo several calls simultaneously. It took me a while to figure this out. I only found this in a YouTube tutorial of streaming Idiots... This is not clearly stated in the vMix knowledge base.
 1 user thanked Martin Block for this useful post.
Rank:: Member
That is awesome news.. Thanks so much
We achieved this using a script, then called the script from a Stream Deck. Works a treat :)
Feature Requests
