	PTZOptics camera PTZ control loses connection
 Joined: 9/21/2020(UTC) Posts: 3  Location: Stockholm |
                Every time I start Vmix the camera is streaming but the PTZ control is not working, I must go the Tab and connect it again, then it works until I shut down vmix  |
                I have the same problem.
 I looked for making a shortcut to reconnect each camera but i dindn't find such a command.
 Did you find a solution?
                Hi DieterjI figured out solution for my problem, not sure if it applies to you.
 The cameras must be powered up and connected prior to lunching vmix, this way they connect every time.
 if you power up or connect the camera while vmix is running then you must connect it manually from the PTZ tab under the input setting
 good luck
