Two audio inputs at once || How to
Joined: 10/14/2020(UTC) Posts: 12  Location: Toronto Thanks: 8 times
How can you play two audio inputs at once?
Scenario:
A video file plays (speaker with audio.
Then
I want to fade in a music track 5 seconds after until the end of the video clip.
Trigger the video to start playing the audio input at transition in after set delay and a setvolumefade (audio input volume initially set to 0) Trigger at transition out to stop playing the audio input
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
Or add it as a layer in the multiview tab
 1 user thanked Pepsi(~) for this useful post.
Originally Posted by: Pepsi(~)  Or add it as a layer in the multiview tab Good point, is fade available in multiview or would you advise using triggers?
I use an audio playlist as overlay in a multiview. This is done during an analog clock (web page) during pre event. So people can check audio and video (ticking of the second hand) And audio is fading in and out.
@Pepsi(~) That's a good idea, I'll try that today.
