guidogast
#1 Posted : Tuesday, October 13, 2020 2:29:47 AM(UTC)
guidogast
Netherlands
Was thanked: 34 time(s) in 22 post(s)
For my M5Stick Tally Project, I'd like to expand some functionality to also display whether vMix is streaming/recording. However, I can't find a way in the documentation to read the status of vMix. The WEB API is used to trigger events and turn stuff on or off, and the TCP API only accepts subsciptions to TALLY or ACTS neither of which will give me the information I need. Am I looking past something, or is it simply not possible to know what the status of vMix is using the current API?
Cheers,
Guido
elgarf
#2 Posted : Tuesday, October 13, 2020 2:35:56 AM(UTC)
elgarf
Russian Federation
Was thanked: 227 time(s) in 129 post(s)
TCP API have XMLTEXT command.
Format: XMLTEXT XPATH
Example Request: XMLTEXT vmix/inputs/input[1]/@title\r\n
Example Response: XMLTEXT OK This is the title of the first input\r\n
Example Request: XMLTEXT vmix/inputs/input[6]/text[@name='Headline']\r\n
Example Response: XMLTEXT OK This is the value of Headline text field in title input that is the number 6 (index 5) input.\r\n
Description: Uses the XPATH syntax to retrieve individual text values of the XML state.
Use
Code:
vmix/streaming
Code:
vmix/recording
Code:
vmix/external
As XPath parameter.
guidogast
#3 Posted : Tuesday, October 13, 2020 2:54:23 AM(UTC)
guidogast
Netherlands
Originally Posted by: elgarf Go to Quoted Post
Use
Code:
vmix/streaming
Code:
vmix/recording
Code:
vmix/external
As XPath parameter.
Awesome, thanks elgarf! A follow up question, though:
It isn't possible to subscribe to the XMLTEXT, so I need to poll to know the status. Is there another, more efficient way, of retrieving the data rather than polling it every 5 seconds?
elgarf
#4 Posted : Tuesday, October 13, 2020 3:25:56 AM(UTC)
elgarf
Russian Federation
Not sure you can subscribe to XMLTEXT
https://www.vmix.com/help23/TCPAPI.html
guidogast
#5 Posted : Tuesday, October 13, 2020 3:31:03 AM(UTC)
guidogast
Netherlands
It isn't possible, that's the problem. I'll add it on the features request board.
Thanks for your help elgarf!
User is suspended until 7/1/2029 2:52:17 AM(UTC) najafysmm
#6 Posted : Saturday, December 16, 2023 8:01:00 PM(UTC)
najafysmm
United Arab Emirates
Hi elgarf
i need to know if is there any way to log webapi access in vmix ?
and also send text without disruption via it
i mean right to left arrange + special chars like << ?
