Multiview Into Multiview Doesn't Show...
Joined: 7/15/2018(UTC) Posts: 110  Location: Las Vegas, NV Thanks: 14 times Was thanked: 9 time(s) in 7 post(s)
So I use a blank input to select the video I use for the background of my boxes. So that multiview (the one with the video background) goes into the multiview for boxes... so no matter how many different versions of boxes I make, I can change the ONE multiview to change the background.
I am making a shortcut so I can hit one key that will always give me today's boxes. (Have 5 guests today? Hit this for the 5 box). It'll show on several pages within Stream Deck.
When I add the boxes version I need for the day, the boxes come, but the background does not.
I'm assuming that vMix doesn't allow a Multiview, inside a Multiview, inside a Multiview.
The workaround I have found is to just "Change" the video whenever I need (not delete the input and reimport) versus call for the background via a multiview of it's own.
@ shawntempesta Originally Posted by: shawntempesta  I'm assuming that vMix doesn't allow a Multiview, inside a Multiview, inside a Multiview. That is correct, you can only stack 2 deep. Using a "Mix" Input for the bottom layer is also a workaround. Ice
Figured - just confirming!
I'm using all the mixes, or I'd be there!
