SRT
Adjusting SRT Latency while live
I am running a show today with contributors sending SRT to the main Vmix box. In order to combat artifacting, I increased the latency a bit, but I had to close the input and even start a new instance on a new port. It gave me a port error on the previous port. This required communication to the contributors etc. I would like to have been able to change the latency on the input without having to change the port number. Is this currently possible or something we should feature request?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
change the latency on the caller , not in vMix so you can keep the input
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
I think you cannot modify the latency on the fly, at least not in the VMIX side.
Anyway if your RTMP streaming out is live, you cannot close and add again the SRT input with the same port number. You have to stop the RTMP streaming output, and after add the SRT input again with the same port number. I think is a bug...
SRT
