vMix Call
vMix to vMix call set up
Anyone,
I'm trying to get the best quality out of my remote calls and vMix Calls through a browser limits you to 720p max plus some network auto-throttling. So you can have a vMix to vMix call but I'm not sure how to turn on or engage the camera & microphone at that setting however I do see the throughput jump from 1.4 Mbps to 4 Mbps for a vMix to vMix call. How do I engage camera and more? Anyone try this?
@ mcgeem1
What edition of vMix are you using to “Connect to Call”? By default, all editions will send the Program Output. vMix 4K and vMix Pro will give you options for Outputs 1/2/3 or 4.
Thank you. The current version of Pro, 23.0.0.something. You set up the camera as an input along with microphone then you can see real 4k or 1080p, going through a browser limits you to 720p I believe plus auto-throttling. I've got that working but need to work with the output so that the talent doesn't get feedback on his own feed. This works from vMix basic and up I believe. So I can connect to my pastor with vMix to vMix call and I'm seeing improved quality but I have to figure out as he is speaking, he doesn't feedback into himself. I got an external microphone on him so I can work with it. Not sure yet what impact this has on the network. Limited to 100 down & 20 up and I"m streaming to two social media sites via 3.5 MB bit rate. Working on it
vMix Call
