Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
Howdy! We have a XAML overlay that we press a button to change an image on. I would like for after the image is changed for it to change back to the other image after 15 seconds. Not sure the best way to do this.
call a script at same time when pressing the button to sleep(15000) that will then change the image again
Originally Posted by: doggy  call a script at same time when pressing the button to sleep(15000) that will then change the image again Could you help with an example script? :)
Originally Posted by: kevev  Originally Posted by: doggy  call a script at same time when pressing the button to sleep(15000) that will then change the image again Could you help with an example script? :) Code:
sleep(15000)
API.Function("SetImage", ......................)
See helpfiles see shortcuts See scripting for dummies thread
