Slaver
#1 Posted : Friday, October 9, 2020 11:17:20 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
Hello Folks,
i have the following topic.
Production with 4 Cameras, replay and graphics.
I want to record just the camera 1 (without cuts and replay) for the coaches but they want to have the Overlays too.
So i set the recording to output 4 and set the input1 (CAM1) for output 4 with overlays on.
In my recording file i can see just the camera 1 but i have no overlays, although the setting "Overlay On" is on.
Anybody can help?
Thank you in advance
dmwkr
#2 Posted : Saturday, October 10, 2020 12:18:31 AM(UTC)
dmwkr
These Overlay options only work if Output 4 is set to "Output". From the help files:
"If the Source option set to "Output" the Overlay check boxes can be used to customise which overlays are displayed on that particular Output."
https://www.vmix.com/help23/SettingsOutputs.html
To work around that, you could create a virtual input of CAM1, put the overlays in the multiview of this virtual input (usually the clock, maybe the scoreboard) and use that input as a source for output 4.
thanks 1 user thanked dmwkr for this useful post.
Slaver on 10/10/2020(UTC)
Slaver
#3 Posted : Saturday, October 10, 2020 12:23:24 AM(UTC)
Slaver
Great solution!
Thanks a lot.
