ispyisail
#1 Posted : Sunday, August 23, 2020 7:21:25 PM(UTC)
ispyisail
Hi all
It would be good if we could have and "OnTime" event in the triggers
#2 Posted : Sunday, August 23, 2020 8:29:33 PM(UTC)
Can you elaborate a bit more on this?
Practical use example maybe
ispyisail
#3 Posted : Monday, August 24, 2020 5:43:23 AM(UTC)
ispyisail
I'm having the same problem as others
https://forums.vmix.com/...ot-triggering-transition
I have a countdown timer to a livestream that with go live at say 7:00
XAML {0:07:00 PM|mm:ss}
When this timer completes the trigger will not activate
It would be good to trigger on time of day, or even a calendar date for that matter
#4 Posted : Monday, August 24, 2020 6:13:46 AM(UTC)
Like the post you are referring to , this is a clock counting down and not a countdown timer
You can solve this with a script checking the system time and act upon that (examples have been posted in this forum)
ispyisail
#5 Posted : Monday, August 24, 2020 10:57:46 AM(UTC)
ispyisail
"script checking"
I assume this requires the 4k version and above?
This is why this is in the feature request section.
#6 Posted : Monday, August 24, 2020 6:23:45 PM(UTC)
"script checking"
Your assumption is correct
I see your point , turn a higher end flexible possibility into a free fixed lower end addition ;-)
rolahoodriver
#7 Posted : Monday, August 31, 2020 2:47:41 PM(UTC)
rolahoodriver
I would agree. We have two timers set for this and would like to create a video that starts 2 minutes or so before service starts.
{0:6:30 PM|HH:mm:ss} can not be triggered from anything as its going off of system time.
ispyisail
#8 Posted : Tuesday, September 1, 2020 7:41:43 AM(UTC)
ispyisail
+1
exactly my thoughts
Martin Block
#9 Posted : Thursday, October 8, 2020 11:15:10 AM(UTC)
Martin Block
Philippines
+1
Waldemarius
#10 Posted : Thursday, January 20, 2022 10:20:07 PM(UTC)
Waldemarius
Russian Federation
+1
Great feature. Much appreciated. I would start AE-rendered 10-min video timer right 10 mins before the show time
Also this feature would be useful to play "bugs", little overlay banners, at exact time periods
nikosman88
#11 Posted : Friday, January 21, 2022 7:55:50 PM(UTC)
nikosman88
Greece
You can use vsheduler to start automatically a video in a specified time https://forums.vmix.com/...ler---vMixScheduler-Fork
But yes it will be good if in triggers we had on time.
melody
#12 Posted : Monday, January 24, 2022 5:24:05 AM(UTC)
Rank: Guest
Groups:
hi guys,
what about to use API in the windows task scheduler???
Roy Sinclair
#13 Posted : Thursday, January 27, 2022 8:16:31 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Here's the countdown to service start code we use to control when the streaming starts, when the recording starts, all the transitions (play an animated logo, switch to camera in Preview) when the service starts and plan to do more things later when I get the time to write the code (and the need, plus some external hardware changes).
This code also does a true countdown giving Hours, Minutes and Seconds until the service starts instead of the backwards "countdown" by changing the title in our countdown screen (a multiview screen with an animated background image, a countdown bar, Title bar announcing who we are and a nice large window in which the announcement slides are played and in which a pre-service video could also be played (future plans).
The script is started by a trigger on the Countdown screen so when the countdown screen is made Live the script starts.
Note that you could add anything you need in the countdown process including switching to other screens and back since the script won't start a second time if it's already running.
