MeanTime69
#1 Posted : Monday, September 28, 2020 11:55:45 AM(UTC)
MeanTime69
vMix ran the show with 4 cameras, vMix Call, color correction and graphics.
Inside Golden Rams Football with Coach G
Simsyuk
#2 Posted : Thursday, October 8, 2020 7:54:33 AM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
May I suggest to trim the first 10 minutes as it's just a picture and nothing else!
polsten
#3 Posted : Thursday, October 8, 2020 8:53:16 AM(UTC)
polsten
Germany
Hey,
think the show is well edit,
but the audio wasnt that good.
at start all audio was distorted. Your Mic from the Host was picked up directly to an Audio-Interface? watch the gain, so it wont clip.
Also watch the the Audio Channel in vMIx, if it clips set the volume down a bit, like 3dB.
I like to use a free VST Compressor on Audio Channels. But you have to set all values again after restarting vMix, it will not be saved.
https://www.audiopluginsforfree.com/leveling-tool/
I like to set attack at 3, release to 70, ratio 4:1, peak reduction at 30. then test it and set the gain at a level where the peak meter goes to an average of 3dB
