vmix 23.0.0.64 removed the possibility to drag and drop inputs... very unfortunate! is it by mistake or design?
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
you still can ! (why would they ? )
Ok, so for some reason I can't. Tried on two different computers..
I can confirm that it works in vmix 23.0.0.64
Stopped working for me, but with latest update it does again
Joined: 7/1/2020(UTC) Posts: 105  Location: Earth Was thanked: 23 time(s) in 20 post(s)
I just updated from .62 to .65 and lost the ability to drag and drop into inputs...
edit and then after a shutdown/restart it seems to be back. false alarm I guess.
Joined: 1/13/2010(UTC) Posts: 5,336  Location: Gold Coast, Australia Was thanked: 4736 time(s) in 1625 post(s)
Drag and drop is not supported in Windows when the application is run as Administrator. This can happen when running it just after install, since the installer needs to run as Administrator.
So the solution is simply to close vMix then open it again, Drag and Drop restored!
Joined: 3/30/2020(UTC) Posts: 17   Location: Leran Thanks: 14 times
Just ran the Vmix 24 upgrade from 23. The drag and drop stopped working but as soon as I restarted Vmix it all went back to normal again. Seemples and thanks for the advice, Admin 8^)
