hpages
#1 Posted : Tuesday, October 6, 2020 5:09:04 AM(UTC)
hpages
So I have a title and script that I have running with race scoring data. The race data outputs a text of "+1 lap" when in reality it should just be blank. So because i cant change how the data is created I have a script running to replace the text "+1 lap" with "" (blank). This for the most part works, however the "+1 lap" text flashes periodically, so its not a clean replacement. Is there something I'm missing that could eliminate this flashing? I've included the script I'm running for the timing and a video example below.
Thanks for any assistance.
video example (position 5)
Script:
while (true)
if Input.Find("Time Side Bar").Text("Time 2.Text")="+1 lap"
Input.Find("Time Side Bar").Text("Time 2.Text")=""
end if
if Input.Find("Time Side Bar").Text("Time 3.Text")="+1 lap"
Input.Find("Time Side Bar").Text("Time 3.Text")=""
end if
if Input.Find("Time Side Bar").Text("Time 4.Text")="+1 lap"
Input.Find("Time Side Bar").Text("Time 4.Text")=""
end if
if Input.Find("Time Side Bar").Text("Time 5.Text")="+1 lap"
Input.Find("Time Side Bar").Text("Time 5.Text")=""
end if
if Input.Find("Time Side Bar").Text("Time 6.Text")="+1 lap"
Input.Find("Time Side Bar").Text("Time 6.Text")=""
end if
if Input.Find("Time Side Bar").Text("Time 7.Text")="+1 lap"
Input.Find("Time Side Bar").Text("Time 7.Text")=""
end if
if Input.Find("Time Side Bar").Text("Time 8.Text")="+1 lap"
Input.Find("Time Side Bar").Text("Time 8.Text")=""
end if
if Input.Find("Time Side Bar").Text("Time 9.Text")="+1 lap"
Input.Find("Time Side Bar").Text("Time 9.Text")=""
end if
if Input.Find("Time Side Bar").Text("Time 10.Text")="+1 lap"
Input.Find("Time Side Bar").Text("Time 10.Text")=""
end if
End While
#2 Posted : Tuesday, October 6, 2020 5:22:26 AM(UTC)
That's completely normal as you do your value checking after it has been loaaded/displayed already (textblock received the value first)
best option is to use duplicate hidden textboxes , check and proces their values and plce the result in the visible textboxes
Also refine the code (less then 10 lines) with a loop and nr variable = less code written as they are all the same test anyway , only thing that changes is the textbox number value
hpages
#3 Posted : Tuesday, October 6, 2020 6:37:06 AM(UTC)
hpages
I see, I'll give the hidden boxes a run and see how it works for me.
Not sure how to go about the loop and nr variable as I'm just figuring out scripts for these things.
#4 Posted : Tuesday, October 6, 2020 6:39:02 AM(UTC)
something like this (partially tested)
Code:
dim HiddenTextBox As string = ""
do while true
   For X As Integer = 1 To 10
	HiddenTextBox = Input.Find("Time Side Bar").Text("TestBlock"  + X.tostring + ".Text")
	if HiddenText = "+1 lap"
		Input.Find("Time Side Bar").Text("Time "  + X.tostring + ".Text")= ""
	else
		Input.Find("Time Side Bar").Text("Time "  + X.tostring + ".Text")= HiddenTextBox
	end if
   next
loop
hpages
#5 Posted : Tuesday, October 6, 2020 7:23:04 AM(UTC)
hpages
Code:
do while true
	else
	end if
   next
loop
I've attempted the hidden text box method with both my script and the one you provided. The issue still occurs like it has been with my script even though I have it reading the hidden text boxes (ex: Hide Time 2.text)
When I used the code you provided, it actually wiped all of the timing data off regardless of the +1 lap requirement. I used the code below
Code:
do while true
   For X As Integer = 2 To 10
	HiddenTextBox = Input.Find("Time Side Bar").Text("Hide Time"  + X.tostring + ".Text")
	if HiddenTextBox = "+1 lap"
	else
	end if
   next
loop
#6 Posted : Tuesday, October 6, 2020 5:27:51 PM(UTC)
Did you change the data connection too? your source connected to the "Hide Time" textblocks ?
also i noticed you have a habit of using spaces in the names (bad habit) and following your habit you might have missed one after "Hide Time" in the code
hpages on 10/8/2020(UTC)
hpages
#7 Posted : Thursday, October 8, 2020 5:27:23 AM(UTC)
hpages
Thank you for your script and guidance! I was able to figure out what I was doing wrong and managed to make some additions to your script to suit our needs as well! Everything works great now!
I'm also making a note to not use spaces in my titling from now on.
Script I ended up with:
Code:
do while true
	HiddenTextBox = Input.Find("Time Side Bar").Text("Hide_Time_"+X.tostring+".Text")
	if HiddenTextBox = "+1 lap" or HiddenTextBox = ""
            Input.Find("Time Side Bar").Text("Plus Sign "  + X.tostring + ".Text")= ""
     elseif HiddenTextBox = "+2 laps"
		Input.Find("Time Side Bar").Text("Time "  + X.tostring + ".Text")= "1 lap"
            Input.Find("Time Side Bar").Text("Plus Sign "  + X.tostring + ".Text")= "+"
      else
      end if
   next
loop
hpages
#8 Posted : Friday, October 9, 2020 4:55:51 AM(UTC)
hpages
Code:
do while true
	else
	end if
   next
loop
Follow up to this,
Is there a way I can make the text boxes fill in three numbers after the decimal point? I know there's a way to format the text and I haven't stumbled across a solution yet.
EX: "0.6" would be displayed "0.600" and "2" would be displayed "2.000"
