Litti05
#1 Posted : Monday, October 5, 2020 3:42:56 AM(UTC)
Litti05
Germany
I'm trying to implement the Qoocam 8K Enterprise as input source at Vmix.
At VLC Player it's easy with the following link:
rtsp://192.168.178.75:8554
Video and audio runs well.
At Vmix I'm getting port errors all the time (Invalid RTSP Response Code: 200; RTSP over TCP)
The only possibility to get the video shown as input source is to use "VLC(RTMP,UDP,RTP,RTSP,TS)"Stream option.
But with this option there is no Audio available/detectable.
The rtsp Address is given in a fix way directely from the camera.
Does anybody have an idea?
elvis55
#2 Posted : Monday, October 5, 2020 4:10:47 AM(UTC)
elvis55
Switzerland
Was thanked: 57 time(s) in 51 post(s)
Port Description: RTSP Alternate (alt to port 554)
LeoSca
#3 Posted : Wednesday, October 7, 2020 2:19:21 AM(UTC)
LeoSca
Uruguay
How are you. I am working with Vmix and using VLC (RTMP, UDP, RTP, RTSP, TS) and the IP rtsp: //192.168.178.75: 8554. I can see the image correctly. What I have problem is controlling the parameters of the camera by the cell phone having the camera at 20 meters via LAN cable. How do you control it? Do you have any software that does it?
