Joined: 8/12/2019(UTC) Posts: 10  Location: Houston TX Thanks: 20 times Was thanked: 3 time(s) in 2 post(s)
I probably missed the part where this is by design. But I can't seem to get a Virtual Set to transmit live in a MultiView layer of a mix. It will work with a normal MultiView but not the mix. Also I can get other inputs to work in the mix's MultiView Layers. It shows up in the preview window as intended. But disappears when switched to live. Is this intended?
