GT
Is this two stage animation possible?
Thanks: 8 times Was thanked: 12 time(s) in 9 post(s)
Hi, I'm trying to recreate an adobe lower thirds template in GT designer, and I can't figure out if it is possible to make this transitionOut animation. I have played around with multiple animations, but I need to stop the first animation before it finishes. Is there any way to do this in GT designer? See attached animated GIF. Thanks!  animExample.gif (341kb) downloaded 47 time(s).
Talking about the bars resizing first before flying out? : No but image sequence might do it or use the legacy xaml titling option (will need to do some "coding")
Originally Posted by: doggy  Talking about the bars resizing first before flying out? : No but image sequence might do it or use the legacy xaml titling option (will need to do some "coding") Yes, that's what I meant. Thanks for confirming its not doable with GT animations. I didn't know you could scale an image sequence to the text, but it looks like it might be possible, so this could be a solution. Thanks!
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
You could do it by adding another layer underneath the larger rectangles that is the size of the rectangles you want for the second stage. I've done something like that before.
Nice thing about vMix , one can always fake things a bit ;-) Click to see GIF  splitanim.gif (142kb) downloaded 38 time(s).
GT
