Scott
#1 Posted : Friday, October 2, 2020 5:14:56 AM(UTC)
Scott
Is there a way to change the preview window's input (not output window) with a trigger or shortcut?
I am using vMix to record my video lectures. However, I find the double window distracting. I am trying to create a trigger that replaces the preview window with a black color input after each shortcut-driven fade between inputs to keep me from glancing to the side at the preview during recording.
An alternative would be a way to hide the preview window or make it significantly smaller.
Thanks for the help in advance.
#2 Posted : Friday, October 2, 2020 5:53:54 AM(UTC)
Was thanked: 996 time(s) in 826 post(s)
PreviewInput
Scott
#3 Posted : Friday, October 2, 2020 6:29:42 AM(UTC)
Scott
Originally Posted by: doggy Go to Quoted Post
PreviewInput
I tried that. It makes moves the black color input to the Output Window rather than the Preview Window as one would expect.
Trigger 2.png (6kb) downloaded 0 time(s).
elvis55
#4 Posted : Friday, October 2, 2020 7:28:36 AM(UTC)
elvis55
Switzerland
Was thanked: 57 time(s) in 51 post(s)
ActiveInput
#5 Posted : Friday, October 2, 2020 8:09:33 AM(UTC)
PreviewInput
The delay has to be longer than the transition duration !
Scott
#6 Posted : Saturday, October 3, 2020 3:18:18 AM(UTC)
Scott
PreviewInput
The delay has to be longer than the transition duration!
Ah! That solved it. Thanks!
However, there are a few important things to note:
1) The duration listed in the image is meaningless for this function. Which is why the trigger below image works. vMix doesn't use the duration for all functions which is why one can't edit that field in this function. Ideally, vMix should not display the duration on functions not using it to be more clear on this.
2) The delay does need to be longer than any transition in by other means. In this case, the shortcut I use does a 400 ms fade transition. Thus, the 405 ms delay.
3) There is still a bug in the vMix code as an insufficient delay on this function should just not do anything, rather than get confused an put the input in the Output Window (as the request is to change the Preview Window). Likely not handling an overflow condition as a result of the insufficient delay. Of course, there is no fundamental reason the Preview Window couldn't change before the Output Window completed a fade transition, but this specific case would probably require a good deal of additional programming if I am guessing correctly on how the loop of code is being implemented for these trigger functions.
Trigger 3.png (6kb) downloaded 0 time(s).
