Virtual Set Zoom Reset after Transition Out
Joined: 10/5/2015(UTC) Posts: 47  Location: Norman, Oklahoma
Hi- is there a way to have a virtual set camera zoom reset back after you transition out. Currently were are going to the four box zoom option and manually resetting. I don't even see a trigger setting that would reset. If anyone has an idea please let me know.
Thanks!
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Make a bunch of shortcuts under the same key that individually Set the Pan and Zoom positions to normal values again and call it with the OntransitionOut trigger Dont think the ResetInput will do the right thing
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
The 'SelectIndex' shortcut should work for that (https://www.vmix.com/help23/ShortcutFunctionReference.html). You can select which of the 4 zoom presets you want to recall. I have to admit, I've only used this shortcut with a Steamdeck, not with a Trigger, but hopefully that will achieve what you want.
