Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
On Sunday we resumed a broadcast that we interrupted due to Pandemic in March. We updated vmix to the latest version available and sure of what we had done in March we went on air. However we found ourselves a surprise. We need to manage vmix remotely, we use AnyDesk, Vmix and the PC from which we connect are on the same network. In practice, when I connect with AnyDesk I lose control of Vmix: it starts to close the audio and change the cameras without a real logical sense and certainly not as programmed. Clearly if I don't connect with AnyDesk Vmix it works correctly.
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Try Chrome Remote Desktop
 1 user thanked jelutalica for this useful post.
Originally Posted by: jelutalica  Try Chrome Remote Desktop thank you for the suggestion. Unfortunately Chrome remote desktop is not very practical, now I try Team viewer. Strange all this has happened, until last March everything was working correctly, I don't understand if it was the latest vmix update or an Anydesk update that created all this
Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: STADIORADIO  Originally Posted by: jelutalica  Try Chrome Remote Desktop thank you for the suggestion. Unfortunately Chrome remote desktop is not very practical, now I try Team viewer. Strange all this has happened, until last March everything was working correctly, I don't understand if it was the latest vmix update or an Anydesk update that created all this Try downgrade your Anydesk or V-Mix to see which one are the cause.
 1 user thanked wmsenna for this useful post.
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
I haven't tried it but I would personally try using Parsec for remote control. It's made for gaming with high quality and low latency. :)
 1 user thanked Lennart for this useful post.
The problem is clearly Anydesk. I have used Team Viewer and it works great
Joined: 4/23/2017(UTC) Posts: 1,332  Location: Germany Thanks: 3 times Was thanked: 177 time(s) in 159 post(s)
I have used Teamviewer in the past and can report that it causes issues as well. The frame rate of the recording dropped somehow. Just the recording. Streaming was fine. The OD was unusable. Stop motion. Some setting working locally on the same machine, no issues. I tested PCvisit instead and so far so good. Will see if that causes issues in the future as well.
