Joined: 8/22/2020(UTC) Posts: 10  Location: Depok, West Java Was thanked: 7 time(s) in 4 post(s)
Hi ... Now I'm creating a simple application to control vMix as a CG Engine Actually it is only a client, so it will'not run without vMix Software You can use this software to make your CG work easear with a large number of CG data it would be complex to play direct on vMix Softwar With this apps you can separate it into another machine  Capture.PNG (703kb) downloaded 140 time(s).Tasted: - Windows 10 - vMix 23.0.0.60 x64 (Trial) Here's the link for those who wish to give it a try Draco vMix CG 1.1 This how to use TUTORIAL (English)TUTORIAL (Indonesia)Please let me know if you have any question Best Regards Gilar Kadarsah
 4 users thanked gilar for this useful post.
Update 0.1
- Save and load fiture - Replace righ click function - Keyboard shortcut (Enter Num Key) for take Online and Offline
 1 user thanked gilar for this useful post.
Draco vMix CG 1.0 Stable Version - enable copy paste - enable multiple selection on rundown - end credit count down - many more here the tutorial TUTORIAL DRACO V MIX CG 1.0 Stable VersionDownload link pleas see the first post.
Update 1.1 - Fix Unicode Text Support, Arabic, Chinese etc. - Adding Fast Recall / Numped Keyboard Shortcut for Sequncer - Fix Save Rundown Color
Joined: 12/16/2018(UTC) Posts: 69  Location: Newfoundland & Labrador Thanks: 1 times Was thanked: 6 time(s) in 4 post(s)
I have been looking for an app like this ever since I started using vMix. Coming from an Inscriber and Xpression background, this makes titling very familiar and very easy for a multiple operator vMix scenario.
Many Thanks.
We would love to hire you to help us set up our live stream for our news channel KDRTV News we will compensate you.
Kindly provide us your email or how to contact you.
the download link is not working
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
same "form over quota"
Thanks Gilar
can you please reupload it? the link provided shows a over quota
