vMix Call
vMix Call Firewall Requirements - silly question
Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
In the "vMix Call Firewall Requirements" article it gives some ports that should be opened inbound and outbound. But is this for the caller's network? Or the network where vMix is running?
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
only on the computer, where vmix runs. open a range, e.g. from 50000 upwards and forward these ports to the ip (after your router) of your computer. external 50000-55000 udp to internal 192.....
 1 user thanked Peter1000 for this useful post.
Originally Posted by: Peter1000  only on the computer, where vmix runs. open a range, e.g. from 50000 upwards and forward these ports to the ip (after your router) of your computer. external 50000-55000 udp to internal 192..... Awesome, thank you. I leave the firewall off, but I will open these ports in my AWS security group. Appreciate the help!
vMix Call
