MatthiasHH
#1 Posted : Tuesday, September 22, 2020 10:40:39 PM(UTC)
MatthiasHH
Germany
is it possible to create own function, procedure or similar in the scripting?
#2 Posted : Wednesday, September 23, 2020 12:40:55 AM(UTC)
From the helpfiles:
vMix Scripting supports the majority of VB.NET 2.0 code that will work within a single sub or function.
This means that custom classes and structures are not supported, however you can use the vast majority of the built in base classes in the .NET framework
including the handy System.Net.WebClient for downloading data over the internet.
