Activators – Is This Possible?
Thanks: 53 times Was thanked: 9 time(s) in 3 post(s)
Hello folks – I’d love to be able to turn on an activator when it’s adjacent button is pressed. This sounds simple – but I can’t see a way to do it.
The idea is to act as a cue. So if button A is pressed, that lights up button B as an operator cue. And when button B is pressed, that cues up the light for button C, and so on.
Any ideas gratefully received.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
If there is an event in the list than that should not be a problem from within vMix
And on which controller is this supposed to work ?
a) Event… the closest event I can see is ButtonPress.,.. but this only allows the same button that is currently being pressed to be illuminated, and it stops as soon as the button is released.
b) LaunchPad Mini
Thanks 😊
Originally Posted by: AgentPete  a) Event… the closest event I can see is ButtonPress.,.. but this only allows the same button that is currently being pressed to be illuminated, and it stops as soon as the button is released.
so NO Maybe a little research on how to manipulate (ligth up) a LaunchPad Minibutton to start with
That was what I figured. But needed to ask in case anyone had the same issue and coded their way round it.
