SRT
SRT Miniserver & StreamTo Studio iOS App
Joined: 3/29/2020(UTC) Posts: 103  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
Hi all, I have a job coming up which will have two roaming remote contributors in different parts of the country. I have seen that there is the 'Stream To Studio' app ( https://srtminiserver.com/s2s.html ) available that will run on iOS devices and allow two way vision and audio between remote contributors and the studio via SRT. This solution seems perfect and will hopefully be much more reliable and higher quality than WebRTC. Has anyone used this solution and have any input as to how well it works? I'm hoping I can get my contributors to use it on their iPhone or iPads Thanks
Joined: 12/9/2020(UTC) Posts: 4   Location: Milan Thanks: 2 times
I've used it many times and it's super!
You can also use a proxy to add your custom domain and let them stream to your address.
SRT
