Hi, I wrote a little script to give me bible verses in english and german like this: Quote:[1] In the beginning God created the heavens and the earth. [2] Now the earth was formless and empty, darkness was over the surface of the deep, and the Spirit of God was hovering over the waters.
[1] Im Anfang schuf Gott den Himmel und die Erde. [2] Und die Erde war wüst und leer, und Finsternis war über der Tiefe; und der Geist Gottes schwebte über dem Wasser.
Genesis 1:1-2 For this I use a javascript bookmark in Chrome. My goal is to add each bible verse group as a title preset. We add all bible verses in the beginning and switch to each verse during the sermon, like this:  So I checked the API and I was able to select, next or previous title preset. But I did not find an option to add a value as preset. Is there a way to add values as title presets? For example: Quote:http://127.0.0.1:8088/api/?Function=AddTitlePreset&Input=Text_Main_Verse&Value=MyBibleVerse
Any chance this getting implemented in future versions? Or any other workaround? I don't want to import/export csv files because you cannot write to files using javascript. So using the API would be ideal!
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
If you really want to be able to select a "preset" you will have to go to data sources, meanig , you wil have a to find a way to write to a file first . It will make your live so much easier Why not export your presets to a csv file ?
Originally Posted by: doggy  If you really want to be able to select a "preset" you will have to go to data sources, meanig , you wil have a to find a way to write to a file first . It will make your live so much easier Why not export your presets to a csv file ? As I said, I use a javascript bookmark to extract both german and english translation from a website and copy it to the clipboard. Then I go to vMix and paste the content to the slide. Instead of writing to the clipboard I want to insert the content via the api. Since I use javascript within a browser there is no way to write to a file.
Use an app or some script to save/add the clipboard content to a csv file (autohotkey for example) and your data source will update with each addition ( or you can import it into your presets)
Is easier to select with a variable (data source row ) the row you want
As doggy proposes, I think the easiest approach is to create a .txt or .csv file with the content from the verse and load it as data source. The other solution is overly complicated.
