tdhfox21
#1 Posted : Friday, September 18, 2020 3:17:28 PM(UTC)
tdhfox21
It seems that this has been a problem for ages. But I had no idea about it until I just dropped 1K on a tally system, only to find out that it doesn't even work properly! It seems that tallys only work for whatever shot is in input location 1-whatever. Intuition would suggest that when setting the tally number of an input in the tally light tab, that that would be the light to go on.... but it is not the case. This REALLY NEEDS addressing and fast.
Pepsi(~)
#2 Posted : Friday, September 18, 2020 4:46:29 PM(UTC)
Pepsi(~)
Netherlands
For me the tally light numbering is working without any issues.
I have 3 tally lights. (more to arrive/build) all 3 work perfect.
I had thee first struggle that every input by default get tally number 1. after changing that it worked perfectly
tdhfox21
#3 Posted : Wednesday, May 12, 2021 10:24:02 AM(UTC)
tdhfox21
Pepsi, I am back to trying to work this out again. Can you please give me specifics on what you did?
