ber142
#1 Posted : Wednesday, February 19, 2014 7:59:14 AM(UTC)
ber142
Hi Martin,
I've got some issues with the web API. We're using it frequently (both for tally as via our own control software) and sometimes it's doesn't respond after a while.
I'll try to investigate (probably I do something wrong with the API commands) however I didn't succeed. There is no pattern I can discover. Not in time, not in the data (read: kind of requests).
I digged into the log files and see two patterns:
pattern 1:
11.0.0.66 - CONNECTION ERROR - 16-1-2014 14:07:41
System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
--- End of inner exception stack trace ---
at System.IO.StreamReader.ReadBuffer()
at System.IO.StreamReader.ReadLine()
at szzzzy.n()
at szzzzy.h()
at fi.g(Object a)
11.0.0.66 - CONNECTION ERROR - 16-1-2014 14:08:41
System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.2.50:554
at System.Net.Sockets.TcpClient.Connect(String hostname, Int32 port)
at szzzzy..ctor(Uri a)
at fi.e(StreamType a, String a)
at fi.g(Object a)
11.0.0.66 - CONNECTION ERROR - 16-1-2014 14:11:41
at fi.g(Object a)
pattern 2:
11.0.0.63 - ERROR - 30-12-2013 22:21:04
System.ObjectDisposedException: Cannot access a disposed object.
Object name: 'System.Net.Sockets.Socket'.
at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, SocketError& errorCode)
at System.Net.Sockets.Socket.Send(Byte[] buffer)
at vMix.SimpleProtocol.h(String a)
at vMix.SimpleProtocol.e(SimpleProtocolArgs a)
at ev.h()
11.0.0.63 - ERROR - 30-12-2013 22:24:06
System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.1.6:20555
at vMix.SimpleProtocol..ctor(String hostName, Int32 port)
at ev.e()
at ev.f()
at ev.h()
11.0.0.63 - ERROR - 30-12-2013 22:25:24
at ev.e()
at ev.f()
at ev.h()
As you can see the version numbers differ. Do you have any ideas? Is it a bug in vMix or do I something wrong?
For your information, our own control software runs on a different machine (connected via gigabit LAN).
When I change the port number in vMix and uncheck/check 'Enabled', it works fine on the new port number (since I can't restart vMix during a session).
Hanno.
#2 Posted : Wednesday, February 19, 2014 9:12:34 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Can you find out what kind of error occurs on the control software or browser end?
The errors in the log occur if a browser closes a connection so they can usually be ignored,
but not being able to connect at all after a while is certainly a strange bug I would like to get to the bottom of.
