2 Pages<12
#21 Posted : Wednesday, July 29, 2020 2:15:52 PM(UTC)
23.0.0.60
* Audio buses were set all to enabled by default for inputs without audio, changed this to just Master.
* Virtual Set export feature would not correctly export cropping/clipping settings in regions with , as decimal point.
* Updated SRT to prioritise using NVIDIA encoder on systems such as laptops that have both Intel and NVIDIA encoders available at the same time.
* vMix Media Converter now supports recordings without an audio track.
* Updated licensing agreement and privacy policy to note YouTube terms and conditions.
thanks 14 users thanked admin for this useful post.
stigaard on 7/29/2020(UTC), eduardocfs on 7/29/2020(UTC), rogerone on 7/30/2020(UTC), MycroBeat99 on 7/30/2020(UTC), sinc747 on 7/30/2020(UTC), Simsyuk on 7/30/2020(UTC), ask on 7/30/2020(UTC), avsoundguy on 7/30/2020(UTC), KnightHeart on 8/1/2020(UTC), raugert on 8/3/2020(UTC), DonB on 8/5/2020(UTC), billh2020 on 8/18/2020(UTC), Vince Beck on 9/17/2020(UTC), Roi on 10/9/2020(UTC)
#22 Posted : Wednesday, September 16, 2020 4:25:59 PM(UTC)
23.0.0.61
* Triggers now allow transitions in other mixes when using OnTransitionIn/Out
* Added dynamic buffer for ASIO audio outputs.
This helps situations where there is higher than normal latency on the computer, leading to audio dropouts, particularly with Dante Virtual Soundcard.
* Fixed issue in GT Title Designer where deleting a layer would not delete associated animations.
* Fixed bug in Photos input where re-ordered images would not load in the correct order.
* API.Function in scripting would not transition unless Input was specified, now defaults to transitioning from Preview where no input is specified.
* Added memory leak check for some malfunctioning VST3 plugins.
thanks 11 users thanked admin for this useful post.
doggy on 9/16/2020(UTC), niemi on 9/16/2020(UTC), raugert on 9/17/2020(UTC), sontoloyo on 9/17/2020(UTC), Simsyuk on 9/17/2020(UTC), ask on 9/17/2020(UTC), stigaard on 9/17/2020(UTC), kgoodyer on 9/17/2020(UTC), eduardocfs on 9/19/2020(UTC), sinc747 on 9/22/2020(UTC), KnightHeart on 9/26/2020(UTC)
#23 Posted : Thursday, September 17, 2020 4:47:19 PM(UTC)
23.0.0.62
* Fixed issue with Photos re-ordering fix where it caused sorting issues for Powerpoint instead!
thanks 9 users thanked admin for this useful post.
MarkP on 9/17/2020(UTC), stigaard on 9/17/2020(UTC), kgoodyer on 9/17/2020(UTC), raugert on 9/18/2020(UTC), eduardocfs on 9/19/2020(UTC), Roi on 9/19/2020(UTC), billh2020 on 9/20/2020(UTC), sinc747 on 9/22/2020(UTC), KnightHeart on 9/26/2020(UTC)
#24 Posted : Monday, October 5, 2020 4:03:03 PM(UTC)
23.0.0.64
* Further checks to disable Nahimic added, due to it now being re-installed often with Windows Update driver updates.
* Support for alpha channel in NVIDIA Broadcast virtual camera.
* Right audio channel meter in Master was incorrect when using Send To Master feature on one or more audio buses.
thanks 6 users thanked admin for this useful post.
Roi on 10/5/2020(UTC), ask on 10/6/2020(UTC), sinc747 on 10/6/2020(UTC), raymer on 10/6/2020(UTC), KnightHeart on 10/7/2020(UTC), raugert on 10/10/2020(UTC)
#25 Posted : Thursday, October 8, 2020 7:42:02 PM(UTC)
23.0.0.65
* Added fix for breaking change in Facebook's handling of user photos in vMix Social.
* vMix Social photos will now be cached only for a maximum of 24 hours before downloading again.
* Fix for error when shift-selecting single objects in GT Designer.
thanks 5 users thanked admin for this useful post.
Roi on 10/9/2020(UTC), KnightHeart on 10/9/2020(UTC), Simsyuk on 10/9/2020(UTC), ask on 10/9/2020(UTC), raugert on 10/10/2020(UTC)
#26 Posted : Thursday, November 5, 2020 4:38:59 PM(UTC)
23.0.0.66
* 3rd party apps that use new connections each time to connect to the vMix API can lead
to a resource leak that will result in poor performance and high render times after a few hours.
This release adds a fix for this leak, however we still advise app makers to use single HTTP (keep alive) or TCP API connections when polling the API on a regular basis.
One popular app in particular this fix will help is Bitfocus Companion
* Fix for shortcuts template images not showing the 13th shortcut (spooky!)
thanks 12 users thanked admin for this useful post.
dmwkr on 11/5/2020(UTC), KnightHeart on 11/6/2020(UTC), stevespaw on 11/6/2020(UTC), MeanTime69 on 11/7/2020(UTC), raugert on 11/7/2020(UTC), yimmyo on 11/7/2020(UTC), aldoyh on 11/8/2020(UTC), dasmedienatelier on 11/18/2020(UTC), eduardocfs on 12/19/2020(UTC), stigaard on 1/1/2021(UTC), Roi on 1/1/2021(UTC), bece65 on 1/13/2021(UTC)
#27 Posted : Friday, January 1, 2021 4:40:03 PM(UTC)
23.0.0.67
* YouTube will be enforcing new browser security restrictions for logins starting January 4th.
vMix Social has been updated in this release to comply with these changes.
thanks 10 users thanked admin for this useful post.
BETech on 1/1/2021(UTC), stigaard on 1/1/2021(UTC), Roi on 1/1/2021(UTC), eduardocfs on 1/1/2021(UTC), TheMadPear on 1/2/2021(UTC), mgrayeb on 1/3/2021(UTC), sinc747 on 1/3/2021(UTC), Ario on 1/3/2021(UTC), KnightHeart on 1/5/2021(UTC), dunk on 1/10/2021(UTC)
#28 Posted : Friday, January 29, 2021 3:38:18 PM(UTC)
23.0.0.68
* Adds workaround for recent Google change to some YouTube streams resulting in scheduledStartTime error in vMix Social
* Added support for Facebook Pages using the new web site in vMix Social.
thanks 8 users thanked admin for this useful post.
Build on 1/29/2021(UTC), eduardocfs on 1/29/2021(UTC), AdewaleOmoba on 1/29/2021(UTC), Simsyuk on 1/30/2021(UTC), Andrew Rix on 1/30/2021(UTC), KnightHeart on 1/30/2021(UTC), ask on 1/30/2021(UTC), QuiapoChurch on 1/31/2021(UTC)
2 Pages<12
