Bulldogs
#1 Posted : Tuesday, February 18, 2014 10:16:25 AM(UTC)
Bulldogs
Hello, I'm working with vMix for 2 months.. but I haven't found some stuff's
Does anyone knows - How to make video transition with logo? ( example -
What I need to make in AfterEffects or something like that?
Egriswold
#2 Posted : Tuesday, February 18, 2014 10:36:34 AM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
Yes, After effects is the most common way of producing this type of animation.
The most basic of animations would be to load a PhotoShop file with you logo or graphic in to a After Effects composition matching the resolution you are going to be using in vMix such as 1280x720 @59.94p
Then set key frames to have your graphic fly in then out and at some point if possible have the graphic cover the screen fully. All of this to happen with in 60 to 120 frames depending on desired look. Render the composition out to a PNG sequence.
If you need help setting up the stinger in vMix checkout my quick tutorial video here
Good luck
thanks 1 user thanked Egriswold for this useful post.
richardgatarski on 2/18/2014(UTC)
richardgatarski
#3 Posted : Tuesday, February 18, 2014 4:31:14 PM(UTC)
richardgatarski
Nice tutorial Edward! Thanks for sharing.
