Electronic
#1 Posted : Thursday, September 10, 2020 7:49:23 PM(UTC)
Electronic
Tips For Using Your Cordless Drill Properly And Safely
Buying the best cordless power drill doesn’t mean that you can control everything in your hand. Knowing how to use your machine correctly and safely plays a vital role in an excellent performance while keeping you from danger.
✮✮✮ Useful Link: What is the best drill
Putting your safety on the top priority
No matter which recommended cordless drills you use, it comes with potential hazards when you don’t know how to protect yourself. This is more important when you work with wood.
Thus, while using your cordless drill power tool, make sure to put on a pair of safety goggles to keep your eyes from flying wood chips. The design should be able to cover the sides of your eyes as well.
Wearing a pair of gloves can partly protect your hands from unwanted accidents.
You also should wear long pants and a T-shirt with long sleeves to protect your skin.
If your work produces plenty of dust, remember to wear breathing protection because a dust mask just can protect you from a part of dust. In particular, I highly recommend you use a respirator in case you use this model for a long time and on a regular basis. This protective object is a must for drilling a thing creating a respiratory hazard.
Don’t wear baggy clothing and dangling jewelry because they can catch in your machine.
Choosing the proper bits
The different jobs require different drill bits, so make sure that you always insert the right bits into the chuck.
Here are the rules to pick up the right bits for your needs:
The soft bits like HSS and steel materials work better on more elastic materials like plastic and wood. Meanwhile, harder bits like cobalt and carbine are an excellent solution for metals.
The auger bits and spade bits are significant when going through soft woods, but it’s better to use twist bits, which work safely on any material.
If you make the wrong decision, the bit can break your piece, even ruining itself.
✜✜✜ Check This Out: UserPostedImage Best cordless drill
Setting the cordless drill to forward
To be safe, let you use the forward/reverse selector switch to configure your drill as long as it spins forward (clockwise).
Choosing the right speed and torque
What power setting should you set?
There is not an exact answer, but let you start at the lowest speed and the weakest torque, then increase them if essential.
Starting the cordless drill with the trigger
Before starting your work, you should line up your model to the place where you will hole. Then, apply your pressure to the trigger and not completely depend on the cordless drill’s power.
In some cases, you can create a smaller hole than the final hole size. To deal with this problem, you can make a “pilot hole”; after that, switch to a bigger drill bit to finish the project. The pilot hole can stop your bit from slipping as well as minimize the risk of splitting wood and other damage.
So, how to use your Best Cordless Drills On The Market UserPostedImage properly and safely?
Generally, you have to protect yourself first, then correctly follow the rules like creating a “pilot hole” before making a larger hole.
#2 Posted : Thursday, September 10, 2020 8:18:03 PM(UTC)
Originally Posted by: Electronic Go to Quoted Post
I am wondering if there is a way to create a short cut to get just the audio of a video file to play? Thank you.
Sure: use "Play" with its audio on
