KRTW
#1 Posted : Thursday, September 10, 2020 2:15:57 AM(UTC)
KRTW
Canada
Greetings. Seeking a solution for the following:
I have 3 cameras, Vcall, and mains recording via muticorder all to their own respective SSDs. That's 5 recording streams. And I just added a new show with a second Vcall. I've used multiview to watermark each input - which is great, if that view is up on mains...otherwise the cams record without the watermark, of course.....which means I have to add it to all edits - and that's a pain.Its impossible to exactly the right size and placement.
There are not enough outputs - 4, with 1 being used to record Vcall, 1 for mains, so I can't use output recording....
Is there a solution?
Any help appreciated.
