vMix Call
2 people on call - audio question
For the first time, I have to deal with 2 people on a vmix call in separate locations....How does mix minus work in this situation?
Guest1 needs to hear both interviewer and guest2. Guest2 needs to hear both interviewer and guest1 Interviewer needs to hear guest1 and guest2 but not themself.
Is there special routing that needs to happen?
Any help most appreciated....
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
No special routing necessary. Assuming that the Interviewer is listening through Headphones output: - Mute Interviewer input in Headphones, so he doesn't hear himself - You can send Guest1, Guest2 and Interviewer to Master Bus, and send Master as the Audio Source to the Guests. Because of Auto Mix Minus of vMixCall, the guests will hear each other, but not themselves.
Thank you....I thought this may be the case, but I am going to run a test before the show.....This is BIG show with very famous people - can't afford to have any issues.
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
I am trying same thing (using pro license that should be good for 4 people) As soon as 2nd person logs in it kicks the first person off?? So am I missing something?
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Add a second call. Or third and so on.
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
Correct. Every caller needs their own link. It's not like Zoom where everyone gets the same invite link.
vMix Call
