Hello, I have a problem with scripting. I want to change the score for a basketball game in .gtzip and the script gives me an error, but for .xaml I have no problems...
The script for .xaml is:
dim i = Input.Find("ScorMic.xaml") dim s = Convert.ToInt16(i.Text("ScorGazde")) s=s+3 i.Text("ScorGazde") = Convert.ToString(s)
And for .gtzip is:
dim i = Input.Find("ScorMic.gtzip") dim s = Convert.ToInt16(i.Text("ScorGazde")) s=s+3 i.Text("ScorGazde") = Convert.ToString(s)
I get this error: Script '+3S' Error Line 2: Input string was not in a correct format.
it seems (i.Text("ScorGazde")) is '+3S' you can't convert it to interger without a special function
You need to put .Text to the textblock name to match it with the one your are changing (ScorGazde.Text)
but why use a script in the first place and not a simple shortcut that adds 3 points with a SetText +=3 value
