Joined: 4/30/2020(UTC) Posts: 35  Location: Monza Was thanked: 1 time(s) in 1 post(s)
I don't know for other users, but when I edit documents on Adobe tools i press control-s every two or three actions to update my current project on disk find very useful too the reminder to save when i exit the program (i know, here there is the "last" button, but i see the usage is quite deprecated) and I always have a rollback folder with several previous version of the document
The fact to have to manually overwrite the current vMix project (to me) seems very slow and cause of potential mistakes
so, in my very personal opinion, i feel really very top maxi useful to have the same approach here just my opinion, may be i am wrong, but... may be i am right :-) ciao to all.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: doggy  SavePreset function 1st of all thank you for your answer i was not aware of this function, and I have tested immediately unfortunately the "SavePreset" function, assigned to one of my APCmini device actually open the SAVE AS window, and does not update the current project as the CTRL/CMD-S function does better but not perfect but, again, thank you
Originally Posted by: doggy  SavePreset function AH NO!!! I have seen that if i put the filename with the full drive path (and add the .vmix extention) in the "value" field it works! so thank you so very much one more time!!
