Hi, I am looking for a way to draw live annotations on the output feed going to the stream. I cannot figure out the method to achieve this.
has anyone been in the same need, are there any plugin for vmix to achieve that?
appreciate the support
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
There are several free and paid ones. Here are some of the free ones Some of the paid ones are
- Coach Paint
- Fingerworks
- KLIPDRAW
- Maestro Telestrator
- NewTek NDI® Telestrator
- Panamation 5.0
- RT Software tOG-Sport
- Telestrator on Microsoft Store
Sure there are many more, but these are the ones that I know of. Could use any paint program with screen capture and NDI. Originally Posted by: dabonk  Hi, I am looking for a way to draw live annotations on the output feed going to the stream. I cannot figure out the method to achieve this.
thank you for immediate support! will play out with some
