Martin Block
#1 Posted : Sunday, August 30, 2020 11:35:44 AM(UTC)
Martin Block
Philippines
I have a small issue that I am sure is easy to fix for an experienced user.
So here is the situation:
I am running several videos from a list. All of these are appearing on a screen in a virtual set.
So I created several instances of the set and made a trigger to „SelectIndex“ so the correct list item plays.
Unfortunately, the running time of the video is not displayed.
In order for me to see the running time, I created a shortcut „InputPreview“ selecting the list with the current item and whenever I activate this shortcut, I can now see the current video played on my virtual set with the list in preview showing me the running time. So far so good.
However, I want to automate this, so I do not have to push a button and create a Trigger for each of my virtual sets, so that the current list item played is being shown in Preview.
I am applying the same as I did in my shortcut, i.e. I select „onTransitionIn“, „InputPreview“ „name of List“ (set to current)
But it does not work the same as the shortcut. - Whenever I use this Trigger, I only see the virtual set with the video both in output and preview.
What am I doing wrong?
Thank in advance for the help.
Cheers
dmwkr
#2 Posted : Sunday, August 30, 2020 4:34:48 PM(UTC)
dmwkr
Use a short delay on the trigger, that is longer than the transition duration of the transition you are using.
Martin Block
#3 Posted : Tuesday, September 1, 2020 8:33:29 AM(UTC)
Martin Block
Philippines
Thanks. Worked immediately!
