givros
#1 Posted : Sunday, August 30, 2020 6:08:21 AM(UTC)
givros
Hello
The last 4-5 days i have a problem and can not login to dacast with vmix. It always says that the password or name is wrong (but it is not)
On the other hand Dacast API needs the key and dacast can not provided it since there is problem with their servers
Is there any solution?
If i use the custom RTMP mode i usually have problem with their back up servers
Thank you
