ClaudiuCiprian
#1 Posted : Saturday, August 29, 2020 5:05:49 AM(UTC)
ClaudiuCiprian
Hi Guys,
I am integrating a new TV operation where I installed a Netwek VMC1 switcher connected via 10 Gbps to an Aruba 5406r modular switch. To the same switch I connected a high spec vMix computer (based on HP Z4G4) via 10 Gbps as well. The speed of connection between VMC1 and vMix (files transfer from one to another) is close to 10 Gbps so no problem here. The issue is that we are trying to get into the vMix around 10-12 sources from VMC1 and we get a lot of dropped frames. The maximum number of sources that we can get in a safe mode is 8.
Any idea what we can do to improve the number of NDI sources that could be brought simultaneously in vMix?
To be noted that I opened 12 Newtek NDI Monitor apps on the same computer with the same sources from VMC and all of them are working smoothly simultaneously.
Thank you in advance for your help,
Claudiu
ievgeniilarin
#2 Posted : Tuesday, January 12, 2021 8:09:45 AM(UTC)
ievgeniilarin
Ukraine
I'm experiencing a very similar issue with an Aruba 2930f switch. Have you found a solution to the problem?
