FrankLeggett
#1 Posted : Friday, August 28, 2020 2:32:23 AM(UTC)
FrankLeggett
I was looking for a way to have a countdown clock on the screen fade of shortly after it reached zero such as time to next event. I found and was pointed to the "OnCountdownEnds" trigger but to use this I have to enter the countdown time into the Countdown user interface. I would instead like to have the trigger operate when the countdown ends in a textline in a title page. For instance I would like to enter the following into a text line in a title {0:3:00PM|mm:ss} and when the time reaches 3:00PM or shortly after it triggers the overlay with the title to go off. At present I use a excel data sheet as the source for the textline so I can remotely change the time and after resaving the spreadsheet the countdown will have changed for the next event using the countdown title without me having to change it in VMix.
