ispyisail
#1 Posted : Wednesday, August 26, 2020 6:42:51 AM(UTC)
ispyisail
Hi
I'm wondering if "presenter mode" is possible for overlays.
e.g.
The speaker can see the "current" and "next" text but the audience can only see the "current" text.
#2 Posted : Wednesday, August 26, 2020 7:08:57 AM(UTC)
Manually entered or from data source ?
ispyisail
#3 Posted : Wednesday, August 26, 2020 7:25:38 AM(UTC)
ispyisail
I've looked at both methods
Open to either method.
#4 Posted : Wednesday, August 26, 2020 7:31:08 AM(UTC)
whne linked to a datasource one can specify the row to display ie title can have data from different rows displayed
so maybe playing with shortcuts or script to advance down the list . problem is there is no way to check which row you are on (say for the first name) or keep track of it i know of
same idea but from external app would be less of an issue
dmwkr
#5 Posted : Wednesday, August 26, 2020 8:14:05 AM(UTC)
dmwkr
Was thanked: 153 time(s) in 137 post(s)
If you have an Excel sheet as a data source, say with two columns like Headline|Text, you can add two columns like nextHeadline|nextText and easily point with a simple cell reference to the contents of the next row. In vMix you can setup a separate title with all four columns for your presenter.
ispyisail
#6 Posted : Wednesday, August 26, 2020 9:12:14 AM(UTC)
ispyisail
Thanks guys
Do you think my request is an edge case?
Or do you think this should be in features request?
I don't really want to get into script workarounds
dmwkr
#7 Posted : Friday, August 28, 2020 6:40:57 AM(UTC)
dmwkr
The solution with Excel does not require any scripting and will work with every vMix version. All you need is the most basic Excel (or OpenOffice, etc.) feature, a cell reference (explained here for example), to enhance your data source. Feel free to ask if you need help.
