Joined: 8/22/2020(UTC) Posts: 10  Location: Depok, West Java Was thanked: 7 time(s) in 4 post(s)
I have read some function of vMix hereThe Document said: The list of functions is constantly growing so the functions below only represent a small fraction of what is available.My question is: Is there any document for all functions The vMix API ? Comment and help would be appreciate Best Regards Gilar Kadarsah | Indonesia
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ gilar,
The most "up-to-date" list will always be in the current version of vMix: Settings ===> Shortcuts ===> "Add/Edit/Clone" buttons ===> "Function" dropdown menu ===> select "All"
(AFAIK, the current list in the Documentation is up-to-date though)
I have made a Github repo with a list of all API functions in vMix. Check the repo out at https://github.com/jensstigaard/vmix-function-listAs Ice stated, it is basically a read out of what is found in the Function dropdown from the interface for adding a new shortcut.
Hi ... @IceStream, @stigaard Thanks for information, i just though there are some function did not shared on documentation Now i'm trying to create PlayList controller client And i'll sahre it in this forum
Thanks: 64 times Was thanked: 157 time(s) in 141 post(s)
Make sure you are using the help files of the current vMix version. Your link points to version 20, current version is 23. https://www.vmix.com/help23/
Originally Posted by: dmwkr  Make sure you are using the help files of the current vMix version. Your link points to version 20, current version is 23. https://www.vmix.com/help23/ Good point - the devil is in the details!
Joined: 5/28/2020(UTC) Posts: 35  Location: London Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Thanks @stigaard, @dmwkr @CrimsonAvenger, It's looks cool, i'll try it. Like i said before i'll share what my apps here hope you would try it, and please let me know if you have any comment here is the link Draco vMix PlayOutBest Regard Gilar Kadarsah
