Feature Requests
vMix Call - Caller numbers export and reset
Joined: 8/22/2020(UTC) Posts: 4  Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Would be super useful to a way to "reset all callers numbers" with a single button click. Also would be great to be able to export all callers to a sheet, excel, txt or other useful file from call manager. Or even a way to select and copy the caller numbers individually from the call manager scren.
Joined: 7/15/2020(UTC) Posts: 15  Thanks Given: Was thanked: 3 time(s) in 2 post(s)
This is a total workaround, but with a little bit of Excel or Google Sheets work and a few LEFT() and RIGHT()'s it's pretty easy to set up a template to accomplish this, so you can just copy/paste the whole initial batch of text when the preset first opens and have it formatted however you'd like. Just make sure to set the cells you're using for the call passcode to 'TEXT' type, otherwise if one starts with a 0, it'll drop it off the number (yup, learned that the hard way).
Feature Requests
